Questions about the Thingworx-Foundation-8-2-1 Ubuntu Installation
tried to install the Thingworx-Foundation-8-2-1 under Ubuntu according to the descritption : https://support.ptc.com/WCMS/files/174097/en/Installing_ThingWorx_8.2_1.0.pdf . I got stuck at page 32, points 2 and 3: I can not find the files  "thingworxPostgresDBSetup.sh" and "MED-61111-CD-074_F000_ThingWorx-Platform-Postgres-8-0- 0.zip". Where can I download them ?
22-Sapphire I
That should be referring to the Install files you download from support.ptc.com as far as I can tell.
So if you have the proper subscription, once you go to Download software, into Thingworx you should see those versions available to you (H2 Postgres MSSQL etc...)
ahorti1-VisitorAuthor
I downloaded it from https://developer.thingworx.com/resources/downloads . There is only download for thingworx foundation. Where are the other ones ?
22-Sapphire I
Depending on your subscription with PTC, all your downloads can be found in support.ptc.com
