pshashipreetham
Radio Button on the List Items
I got the Radio Buttons on the List widget,
Problem: The selected radio Button stays only when we Hover on it. It should be selected after hovering or until the next list item is selected.
Used the following CSS:
ptcs-list::part(item-value)::before{
content:url('../Common/thingworx/widgets/dhxgrid/images/radio-unfilled.png');
margin: 10px;
ptcs-list::part(item-value):hover::before{
content:url('../Common/thingworx/widgets/dhxgrid/images/radio-filled.png');
margin:10px;
Any workarounds over here can be done?
pshashipreetham
So,
Every list widget is bounded by a service that has a DataShape. I have created another Field within the Datashape named HTMLField with Basetype HTML and in Service, I have looped as below
for(var x = 0; x < infotable.length; x++)
var data = {};
row = infoTable.rows[x];
data.HTMLField = "<html><body><input type = 'radio', id = '"+x+"'></input> <label for = '"+x+"'><b>row.displayField</b></label></body></html>
And selected this HTMLField datashape Field as displayField in the ListWidget, which created the Radio Buttons on the Runtime.. and working as expected.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
22-Sapphire I
Are you saying that the selection you make doesn't stay as a solid circle but goes back to a blank circle when you are not hovering over it?
pshashipreetham
Hi @PaiChung,
Thanks for the reply. YES, that is Exactly what is happening!
pshashipreetham
pshashipreetham19-TanzaniteAuthorAnswer
So,
var data = {};
