10 commentaires
2-Explorer
oct. 9, 2015 6:34 PM UTC
I am also wondering the same thing. The guide references "twc_agent" installer files.
Traduire
oct. 12, 2015 1:56 PM UTC
Mike, did you get the entire device kit? If so, can you give me more information on what was included in the kit?
Traduire
oct. 22, 2015 1:48 PM UTC
I reached out to a PTC ThingWorx Consultant and discovered where to get these files.
On the Raspberry Pi page you linked, there is a "Quickstart Console" blue box on the left-hand side. In the box, there is a "Launch" button that prompts you to log in and download the zip file containing the install files.
Hope this helps.
Traduire
oct. 22, 2015 2:01 PM UTC
I got the files as described under the "Launch" button on the side (only appears to work in Chrome, not IE), thanks!
Traduire
minman11-VisitorAuteur
oct. 22, 2015 5:20 PM UTC
So, next step… I have the files on my pi, I’m running twc_agent as described (sudo ./twc_agent) but I get a ton of ws_on_header_value: Websocket connection failed, twWs_Connect: Error trying to connect ws_on_header_value: Invalid ‘connection’ header: Upgrade messages.
When I ping device.cloud.thingworx.com, I get an IP address from DNS (54.208.223.221), but no response to the ping.
What needs to be upgraded here?
Traduire
