rasperryPi with Thingworx issue
Hi all,
I'm trying to follow steps from https://developer.thingworx.com/en/resources/guides/thingworx-raspberry-pi-quickstart but my properties do not update (PiThing is connected).
I use Lua file taken from  step 8 PiTemplate.lua
Running sudo ./luaScriptResource shows as bellow:
[ERROR] 2019-11-03 20:13:25,229 luaScriptProxy::execute: [-1242565552] Error executing script PiThing, Error = Error: ...worx/microserver/etc/custom/templates/PiTemplate.lua:63: attempt to perform arithmetic on local 's' (a nil value)
[ERROR] 2019-11-03 20:13:25,229 luaScriptProxy::app_unlock: [-1242565552] Attempt to unlock app_mutex while not holding it.L= 0x2068730
Any idea what is wrong
thx for all suggestions.
@Gucio Looks like this Lua file needs to be updated. I just reached out to the concerned team for the same and will provide you further updates as soon as I hear back from the team.
Vibhuti
Gucio16-PearlAuthor
As far as I googled - the problem is with string.match(...). In my opinion it should be written: string.match(s,”%d.%d”);
I’ll check it at home.
