Re: Get all user groups for given user
I have a follow up question on this. GetCurrentUserGroups returns a list of Groups the user is directly assigned to, it does not take nested hierarchical groups into account. E. g. I have two groups: Managers and Operators, Managers are member of Operators. But for any Manager the Operators Group is not listed, only the Managers Group itself.
My ultimate goal is to check whether a user is member of a given group to identify permission level.
PaiChungAnswer
22-Sapphire I
May 14, 2019
Once you have the first set of groups, you can do a GetGroups on those entities (or vice versa GetMembers)
i.e. Groups[NameofGroup].GetGroups
Also you can check the Type of each before you run that, because it'll either be of Type Group or User
22-Sapphire I
May 8, 2019
If you are on the latest release of Thingworx I do believe there are 'reverse' style services. I haven't looked into it in depth.
Else you would need to use a recursive service / loop
BennyB16-PearlAuthor
Thanks for your quick response, @PaiChung . Yes, I am working on Thingworx 8.4 but haven't found a fitting method. I avoided a recursive loop, it doesn't feel right to me. On the one hand concerning performance and on the other it may lead to infinite recursion (not in my and not in most cases but potentially). Any pointer to the 'reverse' style services would be a big help.
22-Sapphire I
May 8, 2019
there are some new services like:
CheckPermissionForUser
CheckPermission
CheckDesignTimePermissionForUser
They are on the Things
Potentially those help?
I haven't used them so far.
And in Permissions there is Access Reports which I believe use those services.
