Re: How to Create Data shape Through Service in Thingworx
Following to the same query,
In my case, fieldName baseType is Infotable and a datashape for the respective infotable needs to be added. How can I solve it?
Janakiraman p
20-Turquoise
It'd be the same as what Carles provided in the thread you linked here.  You'll define  var=fieldName  in a similar manner, json format, as the fields in the example. You may also take advantage of using your browser dev tools (f12 in Chrome ) to look up the rest call when manually creating such a property in the datashape.
