Ascherer17
Re: Logging Things w/ Different Properties in Value Stream
It's been a while since posting, but I wanted to follow up a bit more to your comment on performance, @sgreywilson.  In terms of Thingworx 7.1, do you know if there is an actual performance advantage to having multiple defined Value Streams?  I understand your comment that all the data resides in the same table but didn't know if there's any threading or other advantage to creating multiple value streams.  A quantified example could be having 100 Things and deciding whether to assign the same value stream to all 100 or create 10 value streams and assign each to 10 Things.
