Re: REST API Problem(THINGWORX 8.0(MSSQL))
Will ThingWorx 7.4.15  support App key  in the Request Header instead in the URL param.
I believe ThingWorx has always supported passing of the application key in the request header.  Let me know if you have tried to pass the application key in the request header and it appears not to work.
Support
Hi @mapatil.
Please let us know if the response provided by @tmousaw was helpful or if you have remaining questions.  If you are satisfied with the response, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
