Nov 1, 2018 4:32 AM UTC
Re: Timers and Schedulers - Best Practice
Hello Adam,
Thanks for the information it was really useful, but in my case I have 100 things in which I triggered services on 1 second and 1 minute timers so as per your information i have changed execution logic under Timer Thing by calling all the services of a particular things but instead of not going to event system it started increasing the queue Size and it not going down at all.
Have you used this solution and faced the same issue?
Thanks and regards,
Pankaj Phopse
Dec 27, 2018 9:27 AM UTC
Currently I am not facing any issues with reeference to que size , but now I am facing an diffrent issue.
What I learnt is dont use timer one Second and if you are using any oher timer use Timer thing for execution, as explained in Original Post i.e. best practises for timers and schedulers.
Nov 1, 2018 4:35 AM UTC
Hello Adam,
Thanks and regards,
Pankaj Phopse
22-Sapphire I
Nov 1, 2018 6:04 PM UTC
What type of logic are you executing, and is that logic reading any data from DataTables/Streams/ValueStreams or other data sources?
Nov 2, 2018 3:33 AM UTC
I am not calling or querying any data tables, streams or value streams. In a services i am doing basic calculations like Calclulating line status or calculating KPI like OEE, also for these calculation I have passed the inputs which i have defined in services and passing values from Kepware tags.
Nov 2, 2018 6:12 AM UTC
try working with disabling & enabling timer in javascript service with a pause of say 1 sec -- as per your logic
see if that effects the queue size
me.DisableTimer();
logger.warn("in timer event after pause of 1 sec on enable/disable timer");
// your service execution
pause(1000);
me.EnableTimer();
