Reading files from Sharepoint
  • November 24, 2022
  • 4 replies
  • 3801 views
I have been trying to be able to read files from a sharepoint using the sharepoint API's recently but with no luck.
Does anyone on here have any experience with this?
Mainly I'd like to be able to read excel files, but if that is not possible, reading CSV or just normal .txt files would also be fine as a work around.
I've tried several different ways to do this... like GetCSVFile and GetText, neither have worked for me.
Latest error I am facing when trying to read a .txt file using GetText is this:
JavaException: com.thingworx.common.exceptions.InvalidRequestException: Invalid Content Type: application/octet-stream
Not sure why though as I am using the standard "application/json;odata=verbose" as requested by sharepoint in the Accept header field.
Thank you.
Best answer by jensc
So finally managed to get it to work, both reading and writing files on sharepoint.
Here's how I did it in case someone finds this post in the future:
To read a file:
let url = "https://{site_url}/_api/web/GetFileByServerRelativeUrl('/Folder Name/{file_name}')/$value"
let header = {
 "Authorization": "your_bearer_token",
 "Accept": "application/json;odata=verbose",
 "Content-Type": "application/json;odata=verbose",
let params = {
 /* PUT YOUR HTTP PARAMS HERE */
let resultQuery = Resources["ContentLoaderFunctions"].LoadBinary(params);
// this is used to convert the binary result to a string, so not needed to save a file, but could be good if you need to get your data in the service.
var result = me.ConvertBlobToString({
 Blob: resultQuery /* BLOB */
// this saves your file to a thingworx repository of your choice.
Things["YourFileRepository"].SaveBinary({
 path: "/YourFileName.FileEnding" /* STRING */,
 content: resultQuery /* BLOB */
To convert the binary returned from your "LoadBinary" function (me.ConvertBlobToString above):
let blobArray = [];
for (var i = 0; i < Blob.length; i++) blobArray.push(Blob[i]);
let string = base64EncodeBytes({
	array: blobArray
var result = base64DecodeString(string);
Input type is of type "blob" and output is of type "string" for above service.
To create a file on your sharepoint platform:
let url = "https://{site_url}/_api/web/GetFolderByServerRelativeUrl('/Folder Name')/Files/add(url='{file_name}',overwrite=true)";
let header = {
let params = {
 header: header,
 content: <This can be a string or come from a file on your file repository>
 For excel files use PostBinary result will be a blob type:
 	result = Resources["ContentLoaderFunctions"].PostBinary(params);
 you can then parse that into json:
		blob: resultQuery
 result = JSON.parse(string);
 For regular text files uses PostText
 	result will be a JSON
 	result = Resources["ContentLoaderFunctions"].PostText(params);
Hope this helps someone else in case they are struggling with integration to sharepoint.
jensc17-PeridotAuthorAnswer
To read a file:
let header = {
let params = {
let blobArray = [];
	array: blobArray
let header = {
let params = {
 header: header,
		blob: resultQuery
Very nice addition to the community, I highly appreciate you doing this!
