Reading xml from WeatherUnderground
  • May 5, 2016
  • 4 replies
  • 5290 views
I want to replace an existing weather service (from yahoo) with a WeatherUndergroup API.
I haven't been able to get my javascript code to actually read any of the current observation data, it just returns an empty result.
var API = me.WeatherUndergroundAPI;
var features = 'forecast';
var queryLocation = '30009';
var format = 'xml';
var url = 'http://api.wunderground.com/api/' + API + '/' + features + '/'  + '/q/' + queryLocation + '.' + format
var params = {
    url: url,
    timeout : 60
var xmlPage = Resources["ContentLoaderFunctions"].LoadXML(params);
var params = {
    infoTableName : "InfoTable",
    dataShapeName : "WeatherForecast"
me.WeatherHumidity = xmlPage.curren t_observation.relative_humidity;
result = xmlPage.current_observation.relative_humidity;
I'm trying to read from this xml:
<response>
<version>0.1</version>
<termsofService>
http://www.wunderground.com/weather/api/d/terms.html
</termsofService>
<features>
<feature>forecast</feature>
<feature>geolookup</feature>
<feature>conditions</feature>
</features>
<location>...</location>
<current_observation>
<estimated></estimated>
<station_id>KGAALPHA22</station_id>
<observation_time>Last Updated on May 4, 12:39 PM EDT</observation_time>
<observation_time_rfc822>Wed, 04 May 2016 12:39:43 -0400</observation_time_rfc822>
<observation_epoch>1462379983</observation_epoch>
<local_time_rfc822>Wed, 04 May 2016 12:39:55 -0400</local_time_rfc822>
<local_epoch>1462379995</local_epoch>
<local_tz_short>EDT</local_tz_short>
<local_tz_long>America/New_York</local_tz_long>
<local_tz_offset>-0400</local_tz_offset>
<weather>Mostly Cloudy</weather>
<temperature_string>65.7 F (18.7 C)</temperature_string>
<temp_f>65.7</temp_f>
<temp_c>18.7</temp_c>
<relative_humidity>57%</relative_humidity>
<wind_string>From the West at 4.2 MPH Gusting to 6.8 MPH</wind_string>
<wind_dir>West</wind_dir>
<wind_degrees>270</wind_degrees>
<wind_mph>4.2</wind_mph>
<wind_gust_mph>6.8</wind_gust_mph>
<wind_kph>6.8</wind_kph>
<wind_gust_kph>10.9</wind_gust_kph>
<pressure_mb>1009</pressure_mb>
<pressure_in>29.80</pressure_in>
<pressure_trend>0</pressure_trend>
<dewpoint_string>50 F (10 C)</dewpoint_string>
<dewpoint_f>50</dewpoint_f>
<dewpoint_c>10</dewpoint_c>
<heat_index_string>NA</heat_index_string>
<heat_index_f>NA</heat_index_f>
<heat_index_c>NA</heat_index_c>
<windchill_string>NA</windchill_string>
<windchill_f>NA</windchill_f>
<windchill_c>NA</windchill_c>
<feelslike_string>65.7 F (18.7 C)</feelslike_string>
<feelslike_f>65.7</feelslike_f>
<feelslike_c>18.7</feelslike_c>
<visibility_mi>10.0</visibility_mi>
<visibility_km>16.1</visibility_km>
<solarradiation/>
<UV>8</UV>
<precip_1hr_string>0.00 in ( 0 mm)</precip_1hr_string>
<precip_1hr_in>0.00</precip_1hr_in>
<precip_1hr_metric>0</precip_1hr_metric>
<precip_today_string>in ( mm)</precip_today_string>
<precip_today_in/>
<precip_today_metric/>
<icon>mostlycloudy</icon>
<icon_url>http://icons.wxug.com/i/c/k/mostlycloudy.gif</icon_url>
<forecast_url>http://www.wunderground.com/US/GA/Alpharetta.html</forecast_url>
</current_observation>
<forecast>...</forecast>
</response>
Best answer by ttielebein
Hello, when I try to run this query within my web browser, I receive an error message. Are you sure this XML is returning properly to begin with?
URL: http://api.wunderground.com/api/<MY_KEY>/features/q/30009.xml
Error:
<error>
<type>unknownfeature</type>
</error>
That said, when I use a URL which DOES work for me in the browser in my JS, I do parse the XML correctly. Here is my script:
var params = {
    url: "http://api.wunderground.com/api/ee5785ebc5a63ea1/conditions/q/42.7,31.xml",
    timeout : 60
var result = xmlPage.current_observation.relative_humidity;
Let me know if this helps at all!
Tori
Error:
<error>
</error>
var params = {
    timeout : 60
Tori
gsee1-VisitorAuthor
Hi Tori,
Thanks, this helps. However, it's reading everything in as a string, even when I want to assign a numerical value to a property formatted as a number. For numbers, I've been casting them as Number(result), which is working fine. I can't get the dates to import correctly. Any recommendations there?
Hello again,
Great to be of assistance. Have you seen this documentation on implementing dates in ThingWorx? https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS231457
It is in the ThingWorx KCS database. Have you tried this already?
Thanks!
Tori
