Record selection is not working frequently from Grid-widget
I am using ThingWorx Platform Release 9.3 and DatecodeSP9
Not able to select a record from Grid widget. It's not regular but frequent behavior. It occurs mostly when there is a single record in Grid. After reloading the page, it again starts working. Please refer to the video attachment as well
    Please refer this video for understanding my use case.
    FYI..I am using JSON configuration service here to pass some configuration parameters for Grid.
    @KP_10905041 ,
    I have taken a look at the issue you are showing in the video. The behavior of the row does not seem to have row selection configured when there is one row present. You are selecting single fields and not the entire row.
    Can you share your JSON configuration of the Grid?
    I would like to review and try in a test environment.
    Pehowe
