ReferenceError: "window" is not defined
I am not fairly familar with javascript, but found that I could use the following code to get the current URL of the open webpage.
var url = window.location.href;
I am getting an error, "window" is not defined, which I do not understand why.
Is it part of a library not in Thingworx and if so, how can I import that library into Thingworx?
Thank you,
Rami
Hello. Rami Masoud.
Try running this:
document.getElementById("demo").innerHTML = "Page location is " + window.location.href;
What output do you see? And what browser(s) are you running this in?
-- Craig A.
after executing this I got this message,
Message :: ReferenceError: "document" is not defined.
Abhishek Kumar
