Refilling connections on [endpoint 15, uri: ws://************/Thingworx/WS] failed : null
Hello Team,
Need some help on Federation connection
when GetSubscriber status service from publisher is called the below status is shown
And getting the below error from thingworx application logger
Refilling connections on [endpoint 15, uri: ws://***.***.***.***/Thingworx/WS] failed : null
Any help will be greatly appreciated.
Thanks,Regards,
Vijayasanthi
Review any defined Federation subscribers in FederationSubsystem and verify that the server information is correct
go to FederationSubsystem on composer under Subsystems to verify the configurations
check for port number
ensure if firewall is not blocking any connection
ensure the same modifications are applied to server.xml file( tomcat directory) as well.
vijay51-VisitorAuthor
Can you please elaborate on the below point
talking about port number to be mentioned in server.xml file
If ThingWorx hosted by PTC Cloud then Port number should be 8443
same modification is done in server.xml located at <Tomcat_Home>/conf/server.xml to get the ThingWorx Port number
