Reg : JDBC configuration
I'm trying to set up a connection to a MySQL database that I have. I've installed the JDBC Connector extension from the marketplace and that gave me the JdbcCreator and the JDBCExtentionCreator.
Following a PTC document it says to create a new thing and select MySqlServer as the thing template. However, I am unable to see a MySqlServer template.
Any ideas? Have I missed something?
raluca_edu
Please confirm you followed the steps:
  • 1. Open the JdbcCreator mashup, click the “Choose File” button and select the JDBC driver file you want to use from your local file system  ----> you need JDBC for mySQL: https://www.mysql.com/products/connector/
  • 2. Click the “Upload” button and a link will be displayed below the buttons, “Download Extension File”
  • 3. Click this link and save the zip file. This is your extension. You can now import this into the Thingworx platform
  • The imported extension will create a Thing Template with the name of the file plus “JDBCTemplate”. For example a file named “myDbFile.jar” would create a Template named “myDbFileJDBCTemplate”
  • Use this template to create a new thing and connect to your data source using JDBC
Hope it helps,
Raluca Edu
Thank you for your response.
Support
Hi @jaganprasanth.
If Raluca's suggestions allowed you to solve your issue, please mark the appropriate reply as the Accepted Solution for the benefit of others on the community.
--Sharon
