Regarding installation of extension widgets
I have installed the zip file for the widget Progress Gauge and also imported in the local host. But in the widget panel in the mashup, the widget is not available. How can I resolve this?
Where do you get the Extension?
Is the extension imported successfully?
If the Extension is imported successfully without any errors, you can try to restart Thingworx and see if you can see the widget. If you still can't see the widget, I am afraid that it is related to the Extension itself or the Extension doesn't match your Thingworx version.
20-Turquoise
In addition to what was mentioned above, try clearing your browser cache.
20-Turquoise
Just following up to see if you could provide feedback on our questions above.
