Regarding Query and EQFilter on infotables.
Hi team,
I am trying to work on a large infotable. Which will be faster to filter the data Query or EQFilter?
filtered_table = Resources["InfoTableFunctions"].Query({
t: large_infotable/* INFOTABLE */,
query: {
"filters": {
"type": "EQ",
"fieldName": "field",
"value": somevale,
Resources["InfoTableFunctions"].EQFilter({
fieldName: "fieldname" /* STRING */ ,
isCaseSensitive: undefined /* BOOLEAN */ ,
t: large_infotable/* INFOTABLE */ ,
value: somevalue /* STRING */
abhiramkAnswer
Performance will be almost same for both queries. As data is read from a csv file in infotable (memory). It doesn't make much difference. You will get case-sensitive extra option with EQ filter.
Support
Hi @Bhanu_Manoj.
Your question raises some potential concerns:
  • What is the source of the infotable?  Is it coming from a datatable, stream, third-party database, etc.?
  • Since infotables are loaded into memory, how large is it?
We will be better able to answer your question once we understand more about your scenario.
--Sharon
Hi Slangley,
I took the data from .csv file and pushed it into a temporary infotable. Later i am trying to compare a column in the infotable with a string.
col1  col2
hello hai
hello1 test
hello2  test
hello3 test2
Now I want to get the rows in the infotable where col2 = test.
abhiramk1-VisitorAnswer
