Reimporting thingworx extension is not showing reflected changes
Hello Team,
1.Firstly, created an extension from java imported on thingworx.
2.Then deleted the extension and reimported the extension with some changes(after building and packaging extension in java).
3.But now the changes are not getting reflected it is showing the same old imported extension data and status.
What needs to  be done on this?
Any help is appreciated
Support
Hi @vijay5.
Did you check the log for errors?  What type of changes were you making?
Here is an article that may help with import issues and a previous community post.
--Sharon
Try to delete the Extension, restart Tomcat and then reimport the Extension again.
This always did the trick for me.
Cheers,
Michael
Support
Hi @vijay5.
If one of the previous responses helped to resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with similar issues.
Thank you for using our Community!
--Sharon
