Dec 13, 2019 6:48 PM UTC
Remote Binding Example
Team,
Our customer would like to create a service on the thing template that would allow them to create a thing and also do a remote binding to a kepware device,
Please, any code example that we can use for that thing creation and remote binding?
Tks
Chris
amittal-3Answer
Dec 18, 2019 4:06 AM UTC
What you are trying to achieve, I hope you have tried it using manual steps.
So in that case you just need a way to do that programatically, it could be a tricky process, but to answer your question in a precise manner it would need a little more understanding of your model.
However at this point I can point you to some services which you can try, evaluate and then build your own code using it.
1) For dynamically creating a thing you can use -
var params = {
 name: "MyThing" /* STRING */,
 description: "Thing Description" /* STRING */,
 thingTemplateName: "generic" /* THINGTEMPLATENAME */,
 tags: <tags> /* TAGS */
// no return
try
 Resources["EntityServices"].CreateThing(params);
 Things["MyThing"].EnableThing();
 Things["MyThing"].RestartThing();
catch(err)
 logger.debug("Unable to create thing; err: " + String(err));
 Resources["EntityServices"].DeleteThing({name: "MyThing"});
2) For Remote binding use the service "SetRemotePropertyBinding" which is available in GenericThing template
You can also refer to
https://community.ptc.com/t5/ThingWorx-Developers/Binding-KEPServer-Tags-to-Thing-Properties/m-p/573080#M31158
Hope it helps.
Regards
Aditya
amittal-31-VisitorAnswer
var params = {
// no return
try
catch(err)
Hope it helps.
Regards
Aditya
