Remove License in Thingworx 9.2
I have installed Thingworx 9.2 and imported the licenses correctly (I can see them correctly from the Licensing Subsystem Settings).
I was wondering if there was a way to get rid of them in case of errors, in order to import the correct licenses.
Thank you.
Hello @FAntonio,
pls check the article if you face any error:
https://www.ptc.com/en/support/article/cs271439
Revert back if you still face an further challenges.
Regards
Bhawna
Support
Hi @fantonio.
What scenario exists that would require you to replace the license?  Generating a new license with the same entitlements would render the same results.
--Sharon
