Aug 19, 2014 7:53 PM UTC
rename file after upload
I'm trying to rename a file (for consistency) after uploading to a FileRepository be calling the FileRename service after UploadComplete. I am trying to pass the FileName property of the upload widget to the path parameter of the FileRename service. However, I get an error in the app log saying "no path specified."
Is there a way to pass the name of the uploaded file to the renamefile service?
    Aug 19, 2014 8:39 PM UTC
    Hi David,
    Use the
    FullPath
    property of the
    Upload Widget
    instead of FileName, as the path parameter of
    RenameFile
    would expect to get a path input.
    davidcor1-VisitorAuthor
    Aug 19, 2014 8:51 PM UTC
    I tried that as well and still get the same error. It appears to be a permissions error.  It works fine if I am logged into the mashup as an administrator.
    Sep 4, 2014 12:10 AM UTC
    Still looking for an answer to this issue. Any help is appreciated
