Sep 22, 2021 1:47 PM UTC
Replacement for Removed entities in 9.2
I am trying to export one of the entities from 8.4 and import in 9.2  but that entity in 8.4 has dependency on other entities which has been removed in 9.2.
In my case these two entities in 8.4 has been removed in 9.2
Entity Type
Entity Name
Data Shape
• PTC.ISA95.PhysicalAssetCapabilityTestSpecificationThingTemplateList
Thing Template
What is the alternate solution for the removed entities?
PaiChungAnswer
22-Sapphire I
Sep 22, 2021 6:11 PM UTC
You could take everything that you added to the template and move it to a ThingShape and bring that over and then add it to what is appropriate.
Or you can just create these two entities from appropriate base entities where applicable in 9.x
PaiChung22-Sapphire IAnswer
22-Sapphire I
