Replacement for Validator Widget in 8.4
What does PTC recommend that I use as a replacement for the validator widget in TWX 8.4? Seems that the validator widget has been removed in this version (or, at the least, it's be renamed to an unobvious name).
Thoughts?
posipovaAnswer
20-Turquoise
Please note that Validator and Expression widgets were moved into "functions", right-bottom panel of the Mashup builder:
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FRelease_Notes%2Fversion8.4.0ReleaseNotes.html
posipova20-TurquoiseAnswer
20-Turquoise
ague1-VisitorAuthor
Thank you!
Just a head-up for PTC - when I Google 'ThingWorx 8.4 release notes', this is the first page I get: https://support.ptc.com/help/thingworx_platform/r8.4/en/index.html#page/ThingWorx%2FHelp%2FRelease_Notes%2Fversion8.4.0ReleaseNotes.html%23.
^ These docs don't say anything about the change that you mentioned. Not sure why these release notes are different from the url you sent?
Support
Hi @ague.
The easiest way to find it is to search the page:
"The Functions panel for expression and validator functions was added. The panel replaces the Expression and Validator widgets."
--Sharon
