Replacement of deprecated LabelChart widget - bar&lines in TWX 9.3.6+
Hello all,
the LabelChart widget is in new Thingowrx versions signed as depricated. Does anybody already found or created combo chart, which is supported in the Thingworx 9.3.6+.
The chart, which allows visualise pareto information, the combination of bars and lines in the chart like named in https://www.ptc.com/en/support/article/CS323245
slangleyAnswer
Support
Hi @MK_8646268.
ThingWorx 9.4 is now available for download, so please check to see if the combo chart will meet your needs.  If you have any feedback, please let us know.
--Sharon
Support
Hi @MK_8646268.
The combo chart will be available in ThingWorx 9.4 scheduled for release in a few weeks.  Previous widgets are limited when combining graph types.
Note, that even though the legacy widgets are being deprecated, they are still supported.  There has been no decision on the actual date of removal from the product, so feel free to use them for the foreseeable future.
--Sharon
Hi Sharon,
thank you for your answer. You are right that the "label chart" can be used on the mashups, which already exists. Unfortunately to use it on new mashups is not straightforward. You can only copy the chart from old mashups. It is not listed as an available widget in the composer.
Do you see any possibility to export the combo chart widget from TWX 9.4 and install it to version 9.3.6 individually?
We can not upgrade to version 9.4 now because of incompatibility of this version with used Windchill and CAPS versions. (But it is another issue)
Regards
Martin
Support
Hi @MK_8646268.
Within the mashup builder, the standard widgets are displayed by default, but you can select legacy or all widgets in the dropdown to find the widget you need.
It's not possible to export the combo chart from the 9.4 release for import into earlier versions.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @MK_8646268.
--Sharon
I tested new widget and can confirm that it works fine. THX
