Resizing time series chart
Hey Guys,
I am trying to figure out how to resize this time series chart which I believe is inside a contained mashup, but I am not sure and trying to figure out if it is.  I am new to TWX and need a bit of help.
Plan is to move the time series chart to the right to make room for the list widget which displays a drop down of items to plot against the chart. Checking the widget properties, I do not have any options to move or resize the panel / chart and looking for some advice.
Thomas, Jr.dev
rjanardanAnswer
Cut the Time Series Chart(scissor button) and then insert a Layout widget in the area, choosing the number of columns and/or side bar(s) that you need. You can configure the percent of each column as well. Paste the chart in the desired column.
rjanardan16-PearlAnswer
Ecko66512-AmethystAuthor
Thanks for the heads up.
I'll give it go and see how I make out.
Thomas
