Aug 28, 2018 11:59 AM UTC
responsive layout issue
I wanted to create a mashup completely responsive but when I add text box or label in a layout it is asking for panel so when I check for responsiveness in runtime its giving me scrolls and not being responsive. Is there any way in which I can add label and text boxes and other widgets directly in a responsive layout?
V Shalini,
Aug 29, 2018 8:13 AM UTC
Hi...
only Widgets marked with the icon with the 4 arrows can be fully used in a responsive layout - like the Blog, Collection, Fieldset or Value Display.
All other Widgets will need a static panel - like the Button, Checkbox, Numeric Entry or Text Box.
The Panel Widget will fill the full size of a responsive Layout.
You could try to put a panel-in-panel which might give you more flexibility when designing the UI.
Other than that non-responsive Widgets will require a Panel.
Cheers,
Michael
Sep 21, 2018 5:24 AM UTC
Whenever I use panel, and try to check responsiveness by shrinking the screen, I am getting scrolls. Is there any other way to avoid this and make responsiveness efficient?
Dec 6, 2018 11:10 AM UTC
Following.
