7-Bedrock
Responsiveness of widgets
 If I fixed the container size than everything remain same in all resolution. to make it responsive I used the stretch container setting.
on normal laptop screen it looks like this.
On full it stretch properly as I want but screen get little disturb and dropdown size increase a little bit if I select anything.
*I want to know how I make the whole screen responsive. at any resolution it will stretch accordingly.*
specially the date and time picker
Support
Hi @AC_10460579.
How does it look if you try the "none" or "wrapped" options?  You may have more luck creating multiple containers if you haven't already.  Can you share the design elements so we have a better idea of what is happening?
What version of ThingWorx are you running?
--Sharon
