Rest_API_Arduino.ino download location
   I am following the guide "How to Read Temperature and Humidity from HTU21D Sensor Using Rest Calls in C for Arduino Yun". I clicked the hyperlink and it goes to PTC IoT Academic Program | ThingWorx. Where do I download the Rest_API_Arduino.ino at the webpage?
   Your learning resources and website, makes it complicated for us beginners to learn. I am also looking for documentation for Rest API and I can't find it at ThingWorx website.
Best Regards,
Markel Robregado
Have you considered using MQTT? Delivering Arduino Collected Data to ThingWorx using MQTT
Thanks for your reply. I will see, if I can use MQTT.
Best Regards,
Markel Robregado
Hi Markel Robregado,
The Rest_API_Arduino.ino file can be downloaded from here. Thank you for your feedback on the documentation.
Here is where you can find documentation on REST API.  You need to login using your PTC Account credentials.
Best regards,
Veronica
