18-Opal
REST API issue in Eclipse
hello~
I have found through the web browser that I can change the property value of THING with the REST API.
So how do I PUT or POST to the REST API in Eclipse?
I've referenced the community's POSTing via a REST call in Java, but it does not work.
Note: POST succeeded but not PUT. I did not make any code changes.
[context: com.thingworx.webservices.context.HttpExecutionContext@49f70e14] [message: JSON Content for said Not Not ValidProperties]
said is a property of restapi Thing.
We have encountered these issues while considering the rest method to transmit data from RS485 communication module.
How do I fix it?
Usually I test REST services using Postman | API Development Environment
If you want to use Eclipse one way will be to create simple REST client as mentioned in this post POSTing via a REST call in Java you said that doesn't work.
According to Javadoc HttpURLConnection (Java Platform SE 8 the HttpURLConnection.setRequestMethod() supports GET POST HEAD OPTIONS PUT DELETE TRACE so you will need to provide more details.
--Marek
CHASEONHO18-OpalAuthor
18-Opal
in Additional
how to use GET method in Eclipse?
--Marek
import okhttp3.OkHttpClient;
import okhttp3.Request;
import okhttp3.Response;
public class Rest {
	 * @throws IOException
	 * @brief Get some information from the server
	void Get() throws IOException {
		OkHttpClient client = new OkHttpClient();
		Request request = new Request.Builder()
				.url("https://academic.cloud.thingworx.com/Thingworx/Things/")
				.get()
				.addHeader("appKey", "XXXXXXXXXXXXXX")
				.addHeader("Content-Type", "application/json")
				.addHeader("Accept", "application/json")
				.addHeader("Cache-Control", "no-cache")
				.addHeader("Token", "XXXXXXXXXXXXXXXX")
				.build();
		Response response = client.newCall(request).execute();
		System.out.println(response.body().string());
for the xxxxxxxx insert the appkey you did create in the thingworx platform…..
import using maven pom.xml …..the following packages
		<dependency>
			<groupId>com.squareup.okio</groupId>
			<artifactId>okio</artifactId>
			<version>2.0.0-RC1</version>
		</dependency>
		<dependency>
			<groupId>com.squareup.okhttp3</groupId>
			<artifactId>okhttp</artifactId>
			<version>3.11.0</version>
		</dependency>
		<dependency>
			<groupId>org.jetbrains.kotlin</groupId>
			<artifactId>kotlin-stdlib</artifactId>
			<version>1.2.61</version>
		</dependency>
		<dependency>
			<artifactId>kotlin-stdlib-common</artifactId>
		</dependency>
enjoy…..the example is using the rest var get….the same can be accomplished with put...note that other inputs are required therefore….
