Rest api Java
I am calling rest api(thingworx url) from java eclipse but throwing error in java.Below is my code
String b64 = Base64.getEncoder().encodeToString(bytes);
//Construct jsoninput body//
JSONObject params=new JSONObject();
params.put("path","/Motivation.pdf");
params.put("content", b64);
//Load pdf to Thingworx repository//
String url = "HiddenServerurlforsafetypurpose/Thingworx/Things/komal_FileRepo/Services/SaveBinary";
URL obj = new URL(url);
HttpURLConnection con = (HttpURLConnection) obj.openConnection();
//add request header
con.setRequestMethod("POST");
con.setRequestProperty("Accept", "application/json");
con.setRequestProperty("Content-Type", "application/json");
con.setRequestProperty("appKey", "removedforsafetypurpose");
con.setRequestProperty("Body", params.toJSONString());
// Send post request
con.setDoOutput(true);
DataOutputStream wr = new DataOutputStream(con.getOutputStream());
wr.flush();
wr.close();
int responseCode = con.getResponseCode();
System.out.println("\nSending 'POST' request to URL : " + url);
System.out.println("Response Code : " + responseCode);
BufferedReader in = new BufferedReader(new InputStreamReader(con.getInputStream()));
String inputLine;
StringBuilder response = new StringBuilder();
while((inputLine = in.readLine()) != null) {
response.append(inputLine);
in.close();
//print result
System.out.println(response.toString());
Error in Thingworx :
No Path Was Specified
[SECURITY FAILURE Anonymous:@unknown -> /ExampleApplication/IntrusionDetector] Invalid input: context=HTTP header value: body, type(HTTPHeaderValue)=^[a-zA-Z0-9()\-=\*\.\?;,+\/:&_ %$ ¡-￿'"]*$, input={"path":"\/Motivation.pdf","content":"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"}
If i am passing same input to the service in thingworx directly,It is generating pdf.
Please help me how to pass json input
Thank you Velkumar for the much needed support.
Hi @KN_9954684
I think there is some bug in the code. You are setting Body as POST Header Property.
Please refer to this one -
POSTing via a REST call in Java - PTC Community
Making a JSON POST Request With HttpURLConnection | Baeldung
/VR
In the first example they are not setting body.
As per second example I set the body and changed the code but still I am getting error as "No path was specified"
Please check below code
String url = "Hiddenforsecuritypurpose/Things/komal_FileRepo/Services/SaveBinary";
String jsonInputString = "{"+"path"+":"+"/Motivation.pdf"+","+"content"+":"+b64+"}";
con.setRequestProperty("Content-Type", "application/json; charset=UTF-8");
con.setRequestProperty("appKey", "Hidden");
//con.setRequestProperty("Body", jsonInputString);
// DataOutputStream wr = new DataOutputStream(con.getOutputStream());
// wr.flush();
// wr.close();
// int responseCode = con.getResponseCode();
// System.out.println("\nSending 'POST' request to URL : " + url);
// System.out.println("Response Code : " + responseCode);
// BufferedReader in = new BufferedReader(new InputStreamReader(con.getInputStream()));
// String inputLine;
// StringBuilder response = new StringBuilder();
// while((inputLine = in.readLine()) != null) {
// response.append(inputLine);
// in.close();
// //print result
// System.out.println(response.toString());
try(OutputStream os = con.getOutputStream()) {
byte[] input = jsonInputString.getBytes("utf-8");
os.write(input, 0, input.length);
try(BufferedReader br = new BufferedReader(
new InputStreamReader(con.getInputStream(), "utf-8"))) {
String responseLine = null;
while ((responseLine = br.readLine()) != null) {
response.append(responseLine.trim());
Hi @KN_9954684
Please find below code
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.OutputStream;
import java.net.HttpURLConnection;
import java.net.URL;
import java.nio.charset.StandardCharsets;
public class restApiPostRequest {
	public static void main(String[] args) throws IOException {
		// Create URL Instance
		URL url = new URL("http://192.168.86.195:8080/Thingworx/Things/SystemRepository/Services/SaveBinary");
		// Open Connection
		HttpURLConnection conection = (HttpURLConnection) url.openConnection();
		// set HTTP Method
		conection.setRequestMethod("POST");
		// Set Headers to specify content types
		conection.setRequestProperty("Content-Type", "application/json");
		conection.setRequestProperty("Accept", "application/json");
 conection.setRequestProperty("appKey", "2d3571aa-8d70-40ad-b1be-2a32ebb69a1a");
		// to enable write content to request
		conection.setDoOutput(true);
		// making JSON String
		String jsonString = "{ \"content\": \"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\", \"path\": \"/motivation.pdf\" }";
 try (OutputStream os = conection.getOutputStream()) {
 byte[] input = jsonString.getBytes(StandardCharsets.UTF_8);
 // Print Stataus code
 System.out.println("Status Code: "+conection.getResponseCode());
 // Get content from response and print in console. Use try with resource to close streams automatically
 try (BufferedReader br = new BufferedReader(new InputStreamReader(conection.getInputStream(), StandardCharsets.UTF_8))) {
 StringBuilder resp = new StringBuilder();
 String respLine = null;
 while ((respLine = br.readLine()) != null) {
 resp.append(respLine.trim());
 System.out.println(resp.toString());
/VR
