posipovaAnswer
20-Turquoise
Yes, please refer to this article:
https://www.ptc.com/en/support/article?n=CS224211
Ensure your application key has not expired and the use is enabled in PlatformSubsystem.
posipova20-TurquoiseAnswer
20-Turquoise
shreekant1-VisitorAuthor
Thanks for your reply. I have been able to get the GET working using
GET: https://pp-1904021146sg.devportal.ptc.io/Thingworx/Things/SomeTestThing/Properties/SomeNumber
However PUT is not working for me using
PUT: https://pp-1904021146sg.devportal.ptc.io/Thingworx/Things/SomeTestThing/Properties/SomeNumber?method=PUT&value=500&appKey=4bf62b7a-bc9c-423b-93ce-f6f3868ef080
my app key is still functioning as I have tested it through command line tool HTTPie.
what could be the reason? Please help.
shreekant
The issue is resolved for me. I have to enable Allow Request Method Switch option in PlatformSubSystem.
shreekant
