Retrieve Header of Infotable as JSON file for Analytics
Hello everyone,
i am wondering whether you can retrieve the Header of an Infotable as an JSON file in such a way that it fits the format for TWx Analytics Datasets like explained here.
Or maybe the better question is, whether you normaly define these JSON files per hand (since it contains fields like "opType"). I would be already happy if it worked for the required fields only.
Anyway, any help and thoughts on this are appreciated very much.
Kind Regards,
Dominik
nsampatAnswer
Dominik,
You are correct, that these JSON Metadata files are typically created by hand for each dataset.
Regarding the exporting the Infotable to a pre-defined JSON format, you would still have to create the OpType element for the TWA Metadata requirements.
Please let me know if this answers your question.
Neel
nsampat17-PeridotAnswer
Dominik,
Neel
drieder1-VisitorAuthor
Hello Neel,
yes this answers my question, thank you.
Dominik
