3-Newcomer
Retrieving MES Serial Genealogy in ThingWorx via REST Integration
Hello Community,
I'm working on a use case where ThingWorx needs to retrieve serial genealogy/traceability information from an external MES system (Ignition MES) through REST APIs.
For a given serial number, I need to access:
  • Component serials and lot numbers
  • Work order/production order details
I'd like to understand the recommended approach in ThingWorx for:
  • Consuming external REST APIs for genealogy data
  • Modeling and storing genealogy relationships
Has anyone implemented a similar MES-to-ThingWorx genealogy integration? Any best practices, sample architectures, or extension recommendations would be greatly appreciated.
Thanks!
    Support
    Hi ​@RS_14678334,
    In ThingWorx, you can use Resources -> ContentLoaderFunctions to call REST API of external systems. See article https://www.ptc.com/en/support/article/CS237875
    Best regards, Tony
