Return a value from a popup
Hi Everyone...
I'm looking to create a "search" mashup to be used as a popup--basically a textinput widget to enter the search string, and a grid to display the search results. When the popup closes, I need to get the selected row from the grid and push it to a textinput widget on the calling mashup. I know I can use a session variable to store the selected item from the search results and then use a service read the session variable and set the text input field on the parent form, but I'm wondering if there's any other way to accomplish this without using a session variable.
Thanks!
Wayne
