Rhino Version Upgrade
Is it possible to upgrade script engine to the latest Rhino version in ThingWorx? For example, ThingWorx 9.1.0 comes with Rhino 1.7.11. How does one upgrade to Rhino 1.7.14?
Thanks.
Hello @gagarux ,
As per the given Article and the community post, I assume it is better to avoid this for many reasons. Pls check:
https://community.ptc.com/t5/ThingWorx-Developers/Rhino-version/td-p/503900?posno=7&q=Rhino%20version%20in%20ThingWorx&source=search
https://www.ptc.com/en/support/article/cs245405
Kindly let me know if you need any further info.
Regards
Bhawna
gagarux4-ParticipantAuthor
Hi Moonstone. Thanks for your response.
Regarding the post to which you referred the user initially wanted to change Rhino version. However, the change was not necessary in order to solve his particular problem, so he was talked out of doing it. The question still remains, if one really needed to do a Rhino upgrade then how is it done? Is it simply a matter of replacing the Rhino jar with the appropriate version and then restart Apache Tomcat service? I suspect there is more to it than that.
Thanks.
Hello @gagarux ,
Per my knowledge, this is NOT advisable to upgrade Rhino version on your own.
Pls answer the belowmentioned queries:
1. What is the need of Rhino upgrade?
2. Are you facing any issue or security concerns that need Rhino Upgrade?
If yes, then pls let me know and I will open a case on you behalf and this needs to be handled by our CRT team.
Regards
Bhawna
