Run service in reduced user role
If I am an Administrator is it possible to run a service temporarily on a Thing in a user role that is less privileged?
I am working upon a use case wherein the user is not an Administrator. For this I need to keep removing myself from the Administrator's group, check if the mashup/services work, and if they don't request other team member to add myself back to the Administrators group and keep working. I would like to avoid this.
Scenario is:
1. User Jack is an Administrator
2. When service GetData on a Thing runs it has to do it in a user role which is less privileged than an Administrator
3. Jack's user roles should not be affected in any way if this service runs.
Ashish Tamhane
VelkumarAnswer
Hi @ashishtamhane
You can create a dummy user in Thingworx manually and assign the required role. Create an appkey for the user and test the mashup using a dummy user appkey.
To check service permission/privilege, please make a REST API call to Thingworx using a dummy user appKey -Use REST API to Access ThingWorx Part 1 - PTC Community
Refer to the below article:
To access Mashup using AppKey - Article - CS227935 - Accessing Mashups using Application Key (appKey) Authentication in ThingWorx (ptc.com)
To enable AppKey Authentication with SSO - Article - CS279189 - How to Configure SSO Authentication and REST API Application Key Authentication Simultaneously in ThingWorx Platform (ptc.com)
/VR
No, there's no impersonation available directly, except the case when you use a Timer/Scheduler, if you want to rely 100% of the platform features.
Looking at your use-case though, this is typically done by having a Test User with the relevant rights running in a private browser window.
Can you ask your team member/s to create such an user for this purpose?
Hi VladimirRosu,
Thanks for your response. I  forgot to mention that we are using SSO so would this be possible?
Ashish
Velkumar19-TanzaniteAnswer
Hi @ashishtamhane
/VR
