Hello.
A few things to check:
Can you access this with another computer on the same network (not a mobile device)?
Is there any firewall configured on the host system that might be blocking access?
Are you using the correct port to access (maybe not port 80)?
-- Craig A.
Hi CRArko,
I tried it in another computer with same network but it doesnt work.
When I checked the ip address it shows different Ip for two computers with same network.
The port number is right.
Now, what can I do to resolve this issue?
Is there a firewall running on the ThingWorx host computer/VM? If so, can it be temporarily disabled?
If you just try connecting to tomcat. but not the ThingWorx Composer, does that work?
-- Craig A.
