Scheduler Thing Template has Subscription, in that Subscription I need to call a Thing Service
I have a Thing Template of type Scheduler, where I have a Subscription. I have written a some scripts inside that Subscription, which is working fine. But when I try to call a Thing Service that Subscription is not getting executed.
Kindly share a sample code snippet. Thank you
VelkumarAnswer
Hi @SKannapiran
You can call ThingService inside Subscription it will work.
But based on your code, you are retrieving data from the session which is not going to work if it is executed by Scheduler or Timer Event.
For example :
1. I have session value 'testSession' and I can retrieve it from browser session
2. When I try to log that value using the timer event it will be always null because timer/scheduler event will be executed on the server side which doesn't have any session value.
So your service will run when you execute manually. But if you are going to run through scheduler / timer event it is not going to work.
/VR
Hi @SKannapiran
If you have a subscription in Scheduler, the subscription will be triggered based on CRON string configuration.
But when I try to call a Thing Service that Subscription is not getting executed. - Could you please explain this part a bit more. Why do you want to trigger a Scheduler Subscription using the service and its use case.
/VR
Hi VR,
Use Case - To create a dynamic scheduler to send an email with file attachment based on the CRON.
Step 1. To create a dynamic Scheduler using a ThingTemplate of type Scheduler ===> creating successfully
Step 2. This dynamically created Scheduler is triggering based on CRON ===> triggering successfully
Step 3. In that Scheduler we have a Subscription which needs to generate a file and post it on the System Repository folder
Step 4. Upon the file availability, send that file as an email attachment
Step 3 & 4 are written as Subscription in Scheduler. First part of the code is responsible for generating file and second part will send an email.
Code to send email is working fine (second part), but file creation code (first part) is not working. Hence we want to trigger this part through a Thing Service call inside the Subscription.
Hope this clarifies your doubts.
Hi @SKannapiran
Is the service (created in step 3) running without any error when manually executed?
Could you please share the code here and some images?
/VR
