Jul 1, 2025 2:25 PM UTC
Second Y-Axis Line Chart Widget, Number of Series is Dynamic
Hi all,
I am trying to use the second Y-axis functionality on the line widget. The issue I am encountering is the properties displayed on the line chart are dynamically chosen by the user and input into the Data part of the info table, so it is unknown which Y-axis should be used for which property, but sometimes the property values history are very different numbers and could use an automated second Y-axis to make the data look good. Is there any way to do this really with this much uncertainty? I notice if there is a set number of Series that they can be set to either axis 1 or axis 2, but in this case, I don't have a set number of series so cannot really choose and they could need different scales but might not.
Any input is appreciated!
Version 9.7.1
PEHOWEAnswer
Jul 15, 2025 3:37 PM UTC
@JK_10744682 ,
I was heading down the wrong widget. You are using  the Combo Widget.
I believe you are trying to get something that looks like:
There were a few things which needed to be set to get multiple axis.
I have set:
  NumberOfSeries
  ShowYAxis
  NumberOfYAxis
You should then find properties of "YAxis1Max...", YAxis1Min...", YAxis1Num..."
Because of how Composer works. After setting some of the properties you will not find fields you expect. What is required is to save the Mashup and force the Browser to reload the display. The dynamic fields should then be reconfigured.
Jul 7, 2025 12:17 PM UTC
Hello @JK_10744682 ,
I believe that your request to have dynamic number of serries is not supported. I am checking with a subject matter expert to see if this is on the development plan.
Pehowe
Jul 10, 2025 7:13 PM UTC
I took a look at the issue and reviewed with a Subject Matter Expert.
If you leave the Waterfall Widget properties NumberOfSeries as Auto, the number of lines on the chart is driven by the infotable which is provided to the chart. I believe that the Widget support from 1 to 24 lines.
In my testing I used a data shape which had data columns for 5 lines. When there was no data for lines 2-5, I assigned the values in the info table to "undefined".
When the chart is displayed I only see the lines which have data. I was able to switch between 1, 2, or 3 lines on the chart.
Does this meet your needs?
If it is helpful I can share my test case.
Peter
Jul 11, 2025 12:34 PM UTC
Based on your message, it seems that would solve setting the number of series, but wouldn't help with my real issue of setting each of those to a second Y-Axis if the data is far apart between each series. This DisplaySeries1On property is not bindable so even if I was able to dynamically choose which axis each series should be on and what each axis should be I couldn't since this isn't bindable. Maybe I am not fully understanding and your use case can resolve this.
PEHOWE17-PeridotAnswer
@JK_10744682 ,
I have set:
  NumberOfSeries
  ShowYAxis
  NumberOfYAxis
