SelectedRow between Mashups
Good afternoon, sir,
I want to be able to select a row of a grid, click on widget navigation and move to another mashup with several text fields in which the information of the selected row has been loaded.
A priori, I'm trying to do by sending the selected row from one mashup to the other, but I'm not able.
Could you suggest a solution and/or a way to do it?
Thank you very much
Rodrigo Avilés Arias
22-Sapphire I
Through a navigation widget you can pass parameters to the mashup parameters of the mashup you are navigating to.
