May 20, 2025 1:33 PM UTC
Semaphore implementation
HI All,
I am writing program to add a semaphore where I wanted to set the value of flag base on Finished logger message for a particular service in script logs.
Can someone please guide on this please.
Tushar
CharlesJiAnswer
Support
May 29, 2025 12:59 AM UTC
Hi @TusharG,
By mentioning Semaphore, do you mean adding some global value as a flag, which others could monitor and change for specific logic?
For this part, I guess you can use any properties on a Thing to implement such flags.
As for the rest -  monitoring some specific logger messages, I don't think we have such OOTB functionalities to do so. However, I assume you can still achieve this by directly checking & setting the flag in that service code instead of monitoring the message after the service.
CharlesJiCommunity ManagerAnswer
Support
Hi @TusharG,
TusharG4-ParticipantAuthor
Jun 26, 2025 11:25 AM UTC
Thanks Charles,
I have followed the same and it worked in my case.
Tushar
Support
Jun 9, 2025 6:55 AM UTC
Hi @TusharG ,
I just posted a reply to answer your question. If you think it's helpful, it would be great if you could designate it as the Accepted Solution for the benefit of other community members who may have the same question.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
