11-Garnet
Servlet execution error adding entities to a project
We want to add entities to a project but we can´t. We get an error when we try to add a thing to the project in the entities area.
This is the error:
   [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U:] [S: ] [P: ] [T: https-jsse-nio-443-exec-3] Servlet      execution threw an exception
But we can change the project if we edit the thing with the same user.
We are using 9.1.3 version.
Does anybody know what could be the cause of this problem?
Thanks in advance.
Hello @aetxeberria
Can you pls try restarting ThingWorx?
Regards
Bhawna
11-Garnet
Yes, we have restarted Thingworx but we get the same error.
This error was encountered by users earlier:
11-Garnet
The error is the same, but I think that is not the same cause.
        We are not using MSSQL JDBC extension. Our database is postgresql
        We get the error when we add a thing to a project in entities area and save the project in composer. We don´t execute any sql type service...
Hello @aetxeberria
Can you pls follow these steps:
Would you be able to perform the following tests:
* Can you try the same operation using the Administrator user, or a user member of the Administrators group ?
* If still issue, could you do the following:
then share the trace level logs with me.
Regards
Bhawna
