Ascherer17
Set a Property's Category via Script
I'm trying to access and change the "Category" field for Properties on a Thing by using a script. I'd like to be able to set the Category for many Properties at once rather than having to type it in to each individual one. Is there a way to do this?
As far as I know you cannot.
I tried to change description without success, so it should be the same for category.
Maybe you can try write Java extension, but I believe it will not work as well.
