Setting properties in Repeater Widget is possible?
- 1 reply
- 989 views
- Translate All
Hi everyone,
I have a repeater widget and i want to know if it's possible to set properties from the mashup that is inside the repeater to different things
The purpose of this mashup is that, the user will set a value to the text box and this value that was set by the user will be sent to the property inside the thing.
The problem that i am having is that when i set a value to the text box, that value is being put on both things instead of just one of then.
Image of the Mashup below.
Thanks!
