setting up second persistence provider
can i add second persistence provider different from first persistence provider?
ex. first persistence provider: postgresql
second persistence provider: MSSQL
Is a combination like this possible ?
raluca_edu
As far as I know it is not possible, second persistence provider can be Influx DB.
So you can have:
- first persistence provider: PostgresSQL or MSSQL
- Second persistence provider: Influx DB
If you want to connect to another database (not as persistence provider), you can use an extension https://marketplace.ptc.com/apps/195356/jdbc-connector-extension#!overview
Hope it helps,
Raluca Edu
Sruthi15-MoonstoneAuthor
So the second persistence provider should be same as the first right? In case if we want it to be different we can go for Influx db right?
raluca_edu
From my point of view, second persistence provider should be Influx, so is not the same as the first one.
What you want to achieve?
Raluca Edu
