Show all visible properties for multiple things
I want to show a grid of all the properties on my things but I want to dynamically change the columns shown depending on the visibility of the property to the calling user.
eg A battery operated Fan Thing has properties
rpm
setting
chargingStatus
percentRemaining
batteryVoltage
Engineer has access to all properties, and thus a grid will show all properties for each thing. They see all Things
Building manager does not have technical information (rpm and batteryVoltage) these will be missing from the grid. They see all Things
User can only see the same properties as the building manager but only for their device.
I know that I can retrieve a list of the visible properties on an individual thing using GetPropertyValuesAsMultiRowTable but want the visible data for all Things
You will have to build you own service which returns columns depending on visibility.
nadams110-MarbleAuthor
I had a feeling that would be the case,
22-Sapphire I
June 9, 2016
Also don't forget Visibility settings.
You could btw create two mashups and use the same service. What that means though is that all the properties still go to the Client, however only the items you want to display are displayed.
That's NOT full fledged securing the information and I'm not sure if that is harmful or not. It would depend on your use case and the information in the payload if that is acceptable.
