6-Contributor
Show tooltip on disabled buttons
Hi all,
is it possible to show a buttons tooltip even if it is deactivated?
Reason is I want to change the tooltip text to explain to the user _why_ the button has been disabled.
Possibly with custom css but I do not know it.
I often just add a label, whose Visibility is bound to the same source like the Disabled property of the button. Therefore, if the button is disabled the label is visible - showing the cause why it is disabled.
