6-Contributor
Simple loop with columns
I'm having trouble writing a simple loop. I have arrays with three columns.
The columns are Group , Date and Value. The group is the same for all rows.
The same date occurs many times - and I need to sum up the values for the same dates and write them into a new table.
The code I can write in pyhon and VBA - here I can not get around the limitations of JS in ThingWorx
VelkumarAnswer
Hi @Michael_Dezet
Considering Array means InfoTable on the Thingworx side
I have sample dummy data
Below code to calculate each day sales
var rawData = me.dummy;
// Create Infotable to store data
let params3 = {
	infoTableName: undefined /* STRING {"defaultValue":"InfoTable"} */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].CreateInfoTable(params3);
// Add fields to store total and date value
result.AddField({
	"name": "Total",
	"baseType": "INTEGER"
result.AddField({
	"name": "Date",
	"baseType": "DATETIME"
// Get Distinct / Unique Value of Date. Removes duplicate dates from Infotable
// Used to get count for each day
let params = {
	t: rawData /* INFOTABLE */ ,
	columns: "Date" /* STRING */
let distinctDateValues = Resources["InfoTableFunctions"].Distinct(params);
// Iterate Over distinct date values
for (let i = 0; i < distinctDateValues.length; i++) {
	// Create query to filter data based on date
	let query = {
		"filters": {
			"type": "EQ",
			"fieldName": "Date",
			"value": distinctDateValues[i]["Date"] // Date is keyword in JS. Always add suffix / prefix to date variable
	let params = {
		query: query /* QUERY */
	var filteredValue = Resources["InfoTableFunctions"].Query(params);
	// Calculate sum of each day
	let params2 = {
		t: filteredValue /* INFOTABLE */ ,
		columns: "Value" /* STRING */ ,
		aggregates: "SUM" /* STRING */ ,
		groupByColumns: undefined /* STRING */
	var totalForDay = Resources["InfoTableFunctions"].Aggregate(params2);
	// Add calculated value to new infotable
	result.AddRow({
		"Total": totalForDay.SUM_Value,
		"Date": distinctDateValues[i]["Date"]
// Additional : sort column by date
let params4 = {
	sortColumn: "Date" /* STRING */,
	t: result /* INFOTABLE */,
	ascending: false /* BOOLEAN {"defaultValue":true} */
result = Resources["InfoTableFunctions"].Sort(params4);
Result :
Or
If you want the total directly from Infotable, just mention groupByColumns as "Date"
let params2 = {
	t: me.dummy /* INFOTABLE */ ,
	groupByColumns: "Date" /* STRING */
var result = Resources["InfoTableFunctions"].Aggregate(params2);
Please do post here if you have any queries
/VR
Velkumar19-TanzaniteAnswer
Hi @Michael_Dezet
let params3 = {
result.AddField({
	"name": "Total",
result.AddField({
	"name": "Date",
let params = {
	let query = {
		"filters": {
			"type": "EQ",
	let params = {
	let params2 = {
	result.AddRow({
let params4 = {
Result :
Or
let params2 = {
/VR
Hi @Michael_Dezet ,
As continue of @Velkumar post, If you are considering direct array in your case means. Please find the below code,
var inputArray = [
 { Group: 'A', Date: '2023-08-29', Value: 10 },
 { Group: 'A', Date: '2023-08-29', Value: 20 },
 { Group: 'A', Date: '2023-08-30', Value: 15 },
 { Group: 'A', Date: '2023-08-30', Value: 25 },
 { Group: 'A', Date: '2023-09-30', Value: 25 },
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(PTC.SimpleLoop.DS)
let summedTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
 infoTableName: "InfoTable",
 dataShapeName: "PTC.SimpleLoop.DS"
var summedValues = {};
for (var i = 0; i < inputArray.length; i++) {
 var row = inputArray[i];
 var group = row.Group;
 var date = row.Date;
 var value = row.Value;
 var key = group + "_" + date;
 if (!summedValues[key]) {
 summedValues[key] = { Group: group, Date: date, Value: value };
 } else {
 summedValues[key].Value += value;
for (var key in summedValues) {
	var summedRow = summedValues[key];
	// PTC.SimpleLoop.DS entry object
	let newEntry = {
		Group: summedRow.Group, // STRING
		Date: summedRow.Date, // DATETIME
		Value: summedRow.Value // NUMBER
	summedTable.AddRow(summedRow);
result = summedTable;
Output as below
Thanks & Regards,
Arun C
