Simple REST API update with Postman
I am new with ThingWorx and I am trying to update a property Thing on a Mashup with Postman.
(I just want to see a value change on my webpage).
To do this, I have:
- created a Thing "Ju_TestThing" (ThingTemplate : GenericThing) with a property "Ju_value" (Base type : TEXT), default value=10.
- created a Mashup "Ju_TestMashup"
- added a label on the Mashup and connected "Ju_value" to my label with "GetPropertyValues".
- added a "Auto Refresh" widget (interval : 2s)
In System / Subsystems / PlatformSubsystem / Configuration, I have checked "Allow Request Method Switch" and unchecked "Filter Content-Type".
When I click on "View Mashup", it opens a new window with URL like this:
https://pp-XXXXXXXXXXlu.devportal.ptc.io/Thingworx/Runtime/index.html#mashup=Ju_TestMashup&__fromBuilder=112c786d-7cd1-4aa0-826b-db2d9b2324de
Question : Is the end of the URL my appKey ?
In Postman:
- set PUT
- set URL : http://pp-XXXXXXXXXXlu.devportal.ptc.io/Thingworx/Things/Ju_TestThing/Properties/*
- add header "Content-Type" and "Accept" with value "application/json"
- add header "appKey" with value "112c786d-7cd1-4aa0-826b-db2d9b2324de"
- add body : {"Ju_value":30}
The result is "405 not allowed".
I have tested many others URLs, headers, body, ... each time the result is "405 not allowed".
I have read "REST API Overview and Example" but I still don't understand.
Thanks for your help.
Ju_01Answer
It's still not working on my side. My server is running but no result.
I'm glad to know that my request is good. I stop my tests for the moment.
Best regards
I am sorry you are having problems. A guide that addresses this use exactly is available here:
https://developer.thingworx.com/resources/guides/rest-api-how-guide/property-values-rest-api-how
Taking a look at your URL I see a couple of changes:
Be sure you are using https
I know it is duplicating information, but you must put the property name in both the url and the JSON body:
/Thingworx/Things/Ju_TestThing/Properties/Ju_value
{"Ju_value":"30"}
Since you are sending a string, you also might need to have quotes around the value
Ju_011-VisitorAuthor
I have tried to duplicate information and add quotes around the value:
Example :http://pp-1802071305lu.devportal.ptc.io/Thingworx/Things/Ju_TestThing/Properties/Ju_value
With http, Postman returns me status 405.
With https, Postman returns me status 401.
I have tested with HTTPie like in the documentation.
Here the error :
http -v -j PUT http://pp-1802071305lu.devportal.ptc.io/Thingworx/Things/Ju_TestThing/Properties/Ju_value appKey==50e5cf70-4bcd-44a3-a00d-2dbfb53b82c1 Ju_value="31"
http: error: ConnectionError: HTTPConnectionPool(host='pp-1802071305lu.devportal.ptc.io', port=80): Max retries exceeded with url: /Thingworx/Things/Ju_TestThing/Properties/Ju_value?appKey=50e5cf70-4bcd-44a3-a00d-2dbfb53b82c1 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f16976e0358>: Failed to establish a new connection: [Errno -2] Name or service not known',)) while doing PUT request to URL: http://pp-1802071305lu.devportal.ptc.io/Thingworx/Things/Ju_TestThing/Properties/Ju_value?appKey=50e5cf70-4bcd-44a3-a00d-2dbfb53b82c1
I am looking on google about this error, but not really simple.
I continue my tests, I hope I will find the problem.
That long error is basically a 404 error, your test server is probably not running and you need to restart it by signing into developer.thingworx.com and click on the "server" icon.
I tested your HTTPie command against my server and it worked for me (after replacing your server URL and appKey with mine)
22-Sapphire I
Also make sure that the platform allows the calls, check platform subsystem configuration.
Thanks for your help, but as I said in my first post, I have already check platform subsystem configuration.
