Single server to High Availibility
I am looking for a high level answer. If a customer has Thingworx on a local on-prem single server, and they would like to go to a high availability setup, what is the effort to do so? Relatively easy/hard? Hours/Days? if you need more detail let me know. this was a high level discussion, and not an actual issue at a customer
Hello @dmforbes,
There isn't a defined time to complete the high availability setup, however, there is a high level session on high availability to make an overall impression on the setup. The link is Expert Session: ThingWorx Scalability
